Order Ford 8N Parts Online
8N Electronic Tach
Jim in Pensacol
12-23-2000 15:45:00
I have an 8N with front mounted dist. The electrical system has been converted to 12v with alternator. I think I would like to have an inexpensive aftermarket electronic tachometer so that I can be sure of engine/governor performance. Where in the dist would I take a lead off to run the tach???
Jim in Pensacola
Claus
12-23-2000 16:43:31
 Re: 8N Electronic Tach in reply to Jim in Pensacola, 12-23-2000 15:45:00
If it is the type of tach that runs off the points, you would need to drill a hole in the distributor case and connect it to the brass terminal. I would look for a tach that utilizes the inductive pickup from a spark plug wire. Check with J C Whitney they have one..
Happy Motoring
Claus
Jim in Pensacola
12-24-2000 06:03:25
 Re: Re: 8N Electronic Tach in reply to Claus, 12-23-2000 16:43:31
Claus, This gives me two options! Thanks for the advise. You answer guys are great!
Jim in Pensacola
