Order Ford 8N Parts Online
Long time starting 8n
j arseneault
01-15-2003 15:29:28
hi jo here i have a 498n and when i go to start it. it takes a good 15 to 20 mins to start . somtimes it kicks back through the carb with a poff of white smoke.but when i do get it going i have to leaved the choke on so it will run . whats it sound like to you . thank you moxiejo@aol.com
J ARSENAULT
01-16-2003 15:55:02
 Re: long time starting 8n in reply to j arseneault, 01-15-2003 15:29:28
THANKS FOR YOUR INFO I WILL GIVE IT A TRY THANK YOU
Dave OH
01-15-2003 22:13:32
Three filters. One in tank, one in sediment bowl and one in the elbow at the carb.. If that is it I would run 1/2 can of "Gum-Out" in each tank for a while to clean out the "economizer" in the carb..
Make sure you have fresh gas in the tank.
Dave OH
Mountainman
01-15-2003 20:03:04
j arseneault,
Another possibility is you have a vaccuum leak in the manifold or carb.
hth
Mountainman...CA
bg
01-15-2003 15:54:26
SOunds like it's starved for gas. Clean the carb really well, blow out with compressed air, clean the filters. Adjust the carb at 1 to 1-1/4 turns out on the main screw after you have cleaned it. Once it starts, adjust screw in or out to get smooth running and no hesitation when throttle is opened rapidly. You shouldn't have to use the choke for more than an instant as you crank the tractor.
