2N gear/hydrolic fluid
Jeff R
01-15-2003 11:15:40
I had to add some fluid to the tractor to make the lift work properly and added a universal hydrolic fluid and ran it to clean out the drive way from snow I recently read the post about the fluids/oil for the gears and p t o be that was too late My two questions are I added aboput 3/4 of a gallon and ran the tractor about half an hour
is there much damage that could have happened
can I drain out all the oil and replace? what do I ask for at my local TSC or New Holland dealers?any help would be appriciated thanks Jeff
Dave OH
01-15-2003 22:52:07
 Re: 2N gear/hydrolic fluid in reply to Jeff R, 01-15-2003 11:15:40
Look in the "Archives" at the top of this page. Llmas has posted what is the definative comparison of the fluids available today.
Dave OH
Les, TN
01-16-2003 00:54:57
 Re: Re: 2N gear/hydrolic fluid in reply to Dave OH, 01-15-2003 22:52:07
That's a good suggestion, but I can never find much over there. The most recent post seems to be 9/7/2001.
What keywords would you search for? llmas oil?
Soundguy
01-15-2003 12:20:11
There is much debate about what to put in our N trannies.
Ford will recomend the 134a transdraulic oil.
The tractor originally used a gl-1 90wt mineral oil. This can be bought at TSC.. in 2.5 or 5 gal pails.. will be traveler brand I believe, and will actually say for Ford 1939- 1956 tractors or something to that effect.
You might check the oil you used.. if it is a universal transdraulic fluid similar to oh.. hyguard ( new jd 303 equivalent ) it may already meet for 134a specs... It should specify on the label.. or maybee they have a website to look up their product specs / equivalents.
Soundguy
Les, TN
01-15-2003 12:10:17
Just yesterday I got this from Mobil Oil:
I would suggest Mobiltrans HD 50. The following is a internet link to the product data sheet:
Technical Support Engineer (WJF)
That technical sheet says this is a GL3 rated lube. What's the difference between the various GL ratings (GL1, GL3, GL5)?
Dan (Myersville) - oops here's the URL
01-16-2003 07:29:22
 Re: Re: 2N gear/hydrolic fluid in reply to Les, TN, 01-15-2003 12:10:17
Here's a very lucid and informed opinion on transmission/final drive/hydraulic lube as it relates to N-series machines:
http://www.ytmag.com//nboard/messages/10625.html
Dan (Myersville)
01-16-2003 07:28:38
