Loader Rear Brackets Wanted PIC
Hec in Omaha
01-14-2003 08:52:09
http://www.villagephotos.com/pubbrowse.asp?selected=116203
Hello all, I am hoping you guys and gals have seen a loader bracket very similiar to this one pictured. What I am looking for is a bracket that is similiar to this with an additional location for the cylinder to pin to. My loader is attached to the rear axle via pins. The rear width of my loader is 30" tube center to tube center. My cylinders are 37" apart from cylinder center to cylinder center. So I need a bracket that has two locations for pins that are not in front of the other as they appear on this bracket but side by side.
As always any help is appreciated.
Hec
Ed Gooding (VA)
01-14-2003 10:32:49
 Re: Loader Rear Brackets Wanted PIC in reply to Hec in Omaha, 01-14-2003 08:52:09
Hec, can you post a pic of the entire loader? In addition to the Dearborn and Wagner loaders, there were several other manufacturers (Freeman, Horn, and others). If I can match your loader up with any of my literature collection, I may be able to offer some helpful info.
Thanks..... .....Ed
'52 8N475798
Hec in Omaha
01-14-2003 11:43:02
 Re: Re: Loader Rear Brackets Wanted PIC in reply to Ed Gooding (VA), 01-14-2003 10:32:49
Thanks for the info. I will get a picture of the loader this weekend and e-mail it to you and post it. Unfortunately it is 40 miles away. There was no identification on the loader. It was soda blasted to bare metal and no ID was found.
Hec
