Advice Please
E. Ray
01-14-2003 06:10:47
Have an NAA that the previous owner painted solid red with brush(is now peeling). Will repaint at some future point but am now more concerned with have a good working tractor. Have make several posts about some charging problems and have received some very good advice (thanks guys). Have been monitoring board and am now asking about oven cleaner (tip I got from this board and have used on other applications with good results) as apposed to sand blasting to remove paint? At this time I have no sand blasting equipment other than compressor. What are your thought about cost effectiveness and results between buying enough cleaner to do job versus buying blasting equipment for this one job? ..... .thanks..... ..Ray
Paint Stripper...
01-14-2003 12:00:52
 Re: Advice Please in reply to E. Ray, 01-14-2003 06:10:47
...Is usually some form of Methelyne Chloride. It absorbs through your skin, and you can breathe in the odorless vapor, and your liver has to process all of it. (Possible benefit for dave#1 here). I used to work at Kodak, and when they (god forbid) spilled a thimble full, the entire HazMat team came out en-mass, and you'd think someone spilled Plutonium. It's a great paint stripper, but it can be nasty. For what it's worth.
Durk(OH)
01-14-2003 11:30:56
I used air craft paint stripper that i bought at the local auto zone store. It comes in spray cans or liquid form. the spray can worked great. You can see the paint bubble up and then you can spray it off or use a plastic putty knife to scrape off the paint. Oven cleaner didnt do as good of job as the aircraft paint remover did. It comes in a white can and found in the paint section.
Ed Gooding (VA)
01-14-2003 10:36:11
Hi Ray. I used about 12 cans of el-cheapo oven cleaner on my 8N. I did just like Al.....sprayed it on at night and hosed off the next day. It took all the grease and most of the paint off. I used a wire cup brush on my angle grinder to get the rest of the paint off. Smaller parts were sand blasted in my blast cabinet.
Hope this helps..... ..... .Ed
'52 8N475798
Al (NC)
01-14-2003 09:37:20
Oven cleaner(I buy the cheapest I can find)is easy and works well. Spray it on in the evening and hose it off in the morning. Generally takes two applications. Removes MOST of the paint and grundge. Then protect the bare metal from rust.
Bill W.
01-14-2003 09:04:57
It works best to sandblast only those parts you can take off the tractor body. If you sandblast the frame/body you are most likely to get sand in bad places unless you go to a lot of trouble to tape and seal up those spots. Use Zane's starch and red devil lye to remove grease and dirt and some paint. let it sit for a day if you can. Pressure wash with hot water if you can. Then wire brush or use heavy paint stripper (marine or aircraft) on the rest. Its a job anyway you cut it but strippers take some of the work out. Put a rust sealer on quickly or paint quickly after cleaning and drying to avoid flash rust. On sandblasting smaller parts, I found playground sand from someplace like Home Depot to work best. If you sandblast badly rusted wheels, you run a risk of burning through and ruining your rims. Wirebrush works best and then seal inside of rims with rust sealer. They will last a long time. Good N-ing.
OH Boy
01-14-2003 08:41:38
While re-doing my tractor, I set up an electrolysis tank to take the corrosion off of some of the more heavily rusted parts. There is an article about this in archives, I think.
I was pleased to find that it not only took off the rust, but loosened the majority of the paint too. I suspect the paint was removed more by chemical reaction with the washing soda in the electrolyte solution than from electrolysis. It peeled right off though.
My parts came out of this process really clean, I would reccommend trying this.
bg
01-14-2003 07:33:11
It'll take the paint off. You can also use Zane's formula of Red Devil Lye and cornstarch. The cornstarch makes the lye solution into a thicker paste that will stick(basically oven cleaner). The stuff is dangerous to skin and mucous membranes. I prefer sandblasting, but that's because that's what I do(or did)for a living. It makes a nice paint-ready surface if you use fine abrasive.
Duffy
01-14-2003 07:26:09
I think the oven cleaner's use was for the grease and oils on the metal, not for removing paint. If you can get down to clean, well adhered paint you could apply a top coat on this. I don't think most oven cleaners as a rule strip paint.
Mike B IL
01-14-2003 06:19:56
Try gasket remover. It is a very high quality paint remover.
ron
01-14-2003 19:50:35
 Re: Re: Advice Please in reply to Mike B IL, 01-14-2003 06:19:56
You are correct there Mike! It does not work as well on gaskets as it should but it will sure strip the paint off. Down to bare metal. KEEP IT OFF SKIN AND EYES!
