Lift capacity---the archives tell me no...but I need reassurance
Bill-AZ
01-13-2003 19:57:23
Being on only one acre the horses beat the pasture down pretty hard. I am looking for a heavy duty aerator to use between turning it over every two years. I found one that looks serious but I dont think the 2N can handle it. It weighs 1200 lbs and they recommend 300 lbs of counter weight. The archives mostly deal with large bales of hay which are gonna be pretty far out behind and while the aerator is up close I am reading that its still too much is that the consensus? Before I pass up the deal I wanted confirmation of my thoughts...its too much right?
Larry (N) ky
01-14-2003 03:50:08
 Re: Lift capacity---the archives tell me no...but I need reassurance in reply to Bill-AZ, 01-13-2003 19:57:23
Bill i made a aerator out of an old hot water heater i put bearing on each end and welded spikes about ever 6" apart. it is a 40 gal water heater and i add as much water as i need to give me the weight i need it works good for me.
Dell (WA)
01-13-2003 20:30:57
Bill..... ....I looked at one of those Airway roller aireators, concept is good, works for the New Zealanders but they use bigger tractors. N's are just a little lite innna the loafers.
Would you consider pulling a "sub-soiler" behind your N? $150 It really doesn't disturb the surface but cuts thru the compacted hardpan caused by your horses hoofs and gets air and water down to the pasture grass roots area. Probably take ya about 1 hr of tractor seat time, depending on your "pattern". Maybe follow with a "chain harrow".
I'm surprized that you have any pasture left after 2 yrs of horses pounding away on it. I'd probably plan on re-seeding right after sub-soiling, of what ever seed the local feed store selling for horse pasture and consider it as a cost of maintenance. You wouldn't have to use full seeding rate..... ...Dell
Bill-AZ
01-13-2003 21:21:13
 Re: Re: Lift capacity---the archives tell me no...but I need reassurance in reply to Dell (WA), 01-13-2003 20:30:57
Dell, that sub soiler is not a bad idea at all. I turned the pasture last winter but it already is so tough its refusing water. I ripped it up good, disked it and replanted bermuda (about our fasteset seasonal grower here). If I don't do something its gonna be concrete by the end of this summer.
As far as its condition the pasture is down to nubs now, maybe more like a slight tint of what was green at one time. I do my best to rotate between pasture and round pen but they like to be out to play.
I'll tell you as far as the aerator, I have done some research and there are some tools out there that are amazing in concept. I can't speak for how well they work, but take a look at some of these links see what you think. Only one will give me the depth that I need.
Link
Link
Thanks for the info!
Soundguy
01-14-2003 04:43:57
 Re: Re: Re: Lift capacity---the archives tell me no...but I need reassurance in reply to Bill-AZ, 01-13-2003 21:21:13
I think everyone right now with horses on confined pasture is having a case of bad 'pasture' hair day. My horses and cow beatt he heck outta my pasture... and eat it down too.
I seed rye in the winter and millet in the spring, and overseed pen. bahia for the growing season. I have round bales out for them and hay cribs in their pen.. but these suckers like to stomp and chew.
Soundguy
Tom Pollard
01-13-2003 21:20:46
I us a airway shatter tine aireator on athletic field. The shatter tines are much heavier than their turf tines. We use it 4 or 5 times a year and it does a great job without tearing things up. I'm not sure of the exact weight but its not that bad my 33 horse new holland is way more than enough tractor
bg
01-13-2003 20:08:43
The 2N Mechanic's Manual lists the heaviest implement at 975 lbs for a 7' disk harrow. With 200 lbs or counterweight, it would be a stretch to pick up 1200 lbs safely.
OH Boy
01-13-2003 19:59:56
Yup its too much if you have to lift it with the three point hitch.
