All I get is a buzz!
Vince
01-13-2003 07:51:02
Completely refurbished my 8N two years ago. She has always been a loyal lady, easy starting, always willing to work and never tiring. Sad to say, I now have to sell her due to a move. She is now fighting me. When I try to start, all I get is that ratcheting "buzz" sound at the starter/solenoid. I already replaced the solenoid thinking that might be the problem. Could it be a voltage regulator problem? Any help appreciated.
kypete
01-14-2003 02:12:08
 Re: All I get is a buzz! in reply to Vince, 01-13-2003 07:51:02
Sounds like a low or dead battery
Try Lite Beer, then.
01-13-2003 11:23:52
Also, try cleaning all the electrical contacts, from the battery to the starter.
Dell (WA)
01-13-2003 08:23:50
Vince..... ...its NOT yer voltage regulator. (unless you've got a discharged battery).
Sometimes the starter button by the tranny shifter gets crudded up contacts and makes it hard to start, fix by replacement.
But in your case, "it buzzes", what ever that means, I'd suspect bad battery cable clamps. Sometimes the acid corrosion gets hidden inside the molded clamp or under the cable insulation. Getta new 'arry chested one-ought (1/0) thick as yer thumb battery cable.
Howsomever, the "ratcheting buzz" could also be a bad starter bendix drive and you need to remove the starter for a visual inspection and cleaning..... .....Dell
Jim (MI)
01-13-2003 07:59:04
Probably either dirty battery cables making poor connection or low battery.
Jim
John,PA
01-13-2003 07:58:15
Hi. Vince,
I have always found that things should "bright and shiny" if you preping for resale. Therefore, mayne you might try shining up the ground wire, battery cables, starting motor "primary" cables.
Sometimes, corrosion, as quietly as it is, will form on metal parts during resting periods, especially if you have a lead-acid battery installed in the machine.
Hope this helps. :)
