Order Ford 8N Parts Online
8N wiring diagram
dave Westlund
01-11-2003 17:43:26
Were can I find a wiring diagram on the net for an 8N? I just purchased an 51 8N. The charging system did not work but they had the battery hooked up with a negative ground. I think it is supose to be positive groud?? Could someone help me figure out how to test the generator? Does the 8N have a cut out or voltage regulator?
sorry for all of the questions.
Thanks Dave
Paul Haas - Pine Island MN
01-11-2003 18:53:45
 Re: 8N wiring diagram in reply to dave Westlund, 01-11-2003 17:43:26
One of the better sites for electrical help
bg
01-11-2003 18:33:25
If it's still 6-volt, it should be + ground. If it's been converted to 12 v, it should be - ground with an alternator, which may be internally regulated, or could be either + or - with a 12 volt generator. If it has a generator, it should have a Voltage regulator. That is unless it has an older model generator with the adjustment screw, in which case it will have a cut-out. Clear as mud, huh?
dave wesrlund
01-11-2003 19:20:55
 Re: Re: 8N wiring diagram in reply to bg, 01-11-2003 18:33:25
Mud is right! It still is 6 volt, but was hooked up negative ground?????
Phil (NJ-AZ-SK)
01-11-2003 22:52:56
 Re: Re: Re: 8N wiring diagram in reply to dave wesrlund, 01-11-2003 19:20:55
Dave, I assume you have changed the battery to +ve
ground ... but before you start the tractor again you need to polarize the GEn..... method depends on the type of regulator/gen
JMHO
Dave westlund
01-12-2003 04:26:45
 Re: Re: Re: Re: 8N wiring diagram in reply to Phil (NJ-AZ-SK), 01-11-2003 22:52:56
yup I did hook up the battery to possitive ground. Do you know how to polarize the generator? I have heard about that, but have never done it myself.
thanks for the help!
Phil (NJ-AZ-SK)
01-12-2003 10:54:43
 Re: Re: Re: Re: Re: 8N wiring diagram in reply to Dave westlund, 01-12-2003 04:26:45
Dave, In all probability the previous owner damaged the regulator when he connected the battery with negative ground and did not polarize. I don�t know which reg/gen you have on that �51 but I will attempt to provide a procedure that will work for both types (without damage) and help trouble shoot the Generator operation.
1. Remove/loosen the FAN belt such that the Generator will Motor (rotate on its own when voltage is applied to the armature & field)
2. Remove the Field wire from the terminal on the Generator (tie the wire back so it does not contact anything). Using a jumper wire connect the field terminal on the generator to Ground/Frame.
3. Use a big old Jumper Cable to connect the Battery �HOT� Post (-ve) to the Armature post (terminal) on the Generator (you will get a spark). If the Field is ground seeking your generator will motor/ rotate (you may have to help it start) If it Motors move to step # 5 , if it does not motor move to step # 4 (but first make sure the field jumper had/has a good ground) 4. If the generator does not motor in step # 3� remove the field jumper end, that was connected to ground, and move it to the armature post(also has the big old Jumper cable attached)If the Generator now motors you system is high seeking , Move to step # 5.
If it does not motor in step # 3 or Step 4 you have a problem in the Generator (but first make sure the Gen field terminal was/is Jumpered to the Gen Amature Terminal in Step 4) 5. Regardless of which step motored the generator you have polarized the generator and its functional/working . Remove Jumpers & reconnect Field wire�. Start Tractor and if it doesn�t charge your regulator has a problem�
Hope this Helps,
Dell (WA)
01-12-2003 08:48:23
Dave..... ....the best way to "polarize" your 8N, is at the square voltage regulator box mounted on the backside of your dash panel. Look thru yer gas door hole and identify it. It should have 4 screws lined up innna row. Sometime ya can read the painted over cover, sometime not, don't matter. The 2-terminals that you are interested in are the BATT and the ARM, and they're side by side and closest to the ammeter. I reach thru with a screwdriver and briefly spark the BATT and ARM terminals, thats all it takes to "polarize" your generator to your battery ground. You do this without the engine running..... ....Dell
Jim.UT
01-11-2003 18:30:50
As mentioned below, nseries.com has diagrams. Here's a link.
jerry
01-11-2003 17:53:33
nseries.com
