6v -- 12v coil
Bill Priday
01-11-2003 17:00:40
Front mount dist. Bought a 12v coil from Don. What, if any, resistors/other doodads need to be installed along with the coil? And do I bypass the factory ballast on the terminal block?
TIA
Bill
Portland TX 9N88110
BC Mike C
01-11-2003 19:01:12
 Re: 6v -- 12v coil in reply to Bill Priday, 01-11-2003 17:00:40
You bypass the original resistor and use the Dell prescribed Radio Shack resistor. Check and make sure the pig tail is long enough to make contact, you may have to stretch it. My opinion only, do so at your own risk, it worked for me. BC Mike C
