I will try this... When it happend, I was plowing snow and got stuck a bit after draggin it into a snow bank. I rasied my plow and put it in reverse to get out, and after doing so I wasnt able to get out of reverse. I put it in low throttle and attempted to shift, but of course got nothing but the griding, as if the clutch wasnt engaged. My shifter acts as if in neutral, but I am in reverse. If I engage the clutch, I am still as if in reverse, even my 3pt connection is engaged and spinnin if the lever if left on. If I have it off (like now) and try to start it, the back wheels spin as I push the starter, even tho the shifter is like nuetral. I can put it in gear (like 1st gear) but I can tell it is not going "all the way" in gear like it should (altho after doing so it goes enough into gear where I can press the starter button) - BUT I cannot get it o shift up into reverse (where it appears to be locked into ). (I have had a SIMILAR problem in the past where sometimes if I was in reverse and I shift to a forward gear, it would do nothing and stall out unless I shifted BACK to reverse and back out of reverse again then SLOWLY put into gear... ) I dont know that much about tractors or cars in general, but am trying to learn... I have had this baby for 3 years now and have been thru a lot with it - but this winter has been a rough one... :)
