Order Ford 8N Parts Online
8N Front distributor/ coil ?
Jim
01-08-2003 17:25:15
1949 8N with front mount dist. The spring on the bottom of the coil glows red hot, and smokes. Is this normal??
Thanks,
Jim
Dave Smith
01-09-2003 04:24:00
 Re: 8N Front distributor/ coil ? in reply to Jim, 01-08-2003 17:25:15
Jim, You are not giving enough information. How do you know the pig tail spring is getting red hot? I can't see inside of my front mount distributer. Tell us what you did.
Dave <*)))><
Jim
01-11-2003 19:36:16
 Re: Re: 8N Front distributor/ coil ? in reply to Dave Smith, 01-09-2003 04:24:00
To see what is happening in the distributor, take off the fan belt, remove the dist. cap and use a mirror. Then you know if the points are sparking. Some automotive shops sell mirrors on extendable handles. Ussually around $5 to $7
Jim
Mike
01-08-2003 23:28:33
Jim,
Did someone try to change it to a 12 volt system? That's been known to cause some problems. Good luck.
Mike
no,,, could it be a bad resistor
01-08-2003 17:33:21
