Order Ford 9N Parts Online
1941 Ford 9N
jeff
01-06-2003 16:04:36
I recently bought what is supposed to be a '41 9N. The serial # on the engine block says 9N166041. According to what I have read this # is too high to be a 9N. It also has what looks to be 2N grill. It has electric start and everything else seems to be 9Nish. Any thoughts?
Thanks
George how do you like the Cub?
01-07-2003 02:10:10
 Re: Re: 1941 Ford 9N in reply to George Willer, 01-06-2003 17:53:45
Motor good. They are sleeveless. Did you overhaul and rebore it or find larger diameter pistons? Bob
George Willer
01-07-2003 12:54:24
 Re: Re: Re: 1941 Ford 9N in reply to George how do you like the Cub?, 01-07-2003 02:10:10
Bob,
I've done it both ways, depending on wear. I haven't been inside the engine of the one in the picture...yet. It is a working tractor. I have a total of nine Cubs. Five are restored and three are works in progress. One is the world's ugliest Cub, and I'm proud of it.
George Willer
MikeC
01-06-2003 16:40:42
 Re: 1941 Ford 9N in reply to jeff, 01-06-2003 16:04:36
According to the serial number that's a late 1944 2N (assuming that the engine is original).
Jeff
01-07-2003 10:10:34
 Re: Re: 1941 Ford 9N in reply to MikeC, 01-06-2003 16:40:42
I thought it was that too, but what about the # having 9N at the beginning? It also has electric start.
Mountainman
01-07-2003 18:35:00
 Re: Re: Re: 1941 Ford 9N in reply to Jeff, 01-07-2003 10:10:34
Jeff,
"but what about the # having 9N at the beginning? It also has electric start."
All 9N/2N tractor's serial numbers begin with 9N.
Most 2N's came with electric start except in the first year - and most were converted after the war ended.
hth
N - joy.
Mountainman...CA
Scott
01-06-2003 16:40:38
Engines can be swaped easily and that is where the serial# is, in 1941 up until the next to last month or so of production of that year had a 1 piece cast alluminum dash and battery tray, smooth side panels, non pressurized radiator and chrome around the guages and knobs, serial# 166041 should have a thin steel dash and battery tray, exsposed bolts to hold the lower side panel on to the front axle support, pressurized radiator and black around the guages radiator cap and hinged hood knob.
Jeff
01-07-2003 10:18:03
 Re: Re: 1941 Ford 9N in reply to Scott, 01-06-2003 16:40:38
Thanks for the info Scott! My 9N has an aluminum dash, non-pressurized radiator, a hinged battery/gas door on top, but exposed bolts that hold on the side panels to the front axle support. Mine also has the mounting bracket ont the left side for a Ferguson sickle-bar mower (Is that rare?) Thanks!
Scott
01-07-2003 16:22:02
 Re: Re: Re: 1941 Ford 9N in reply to Jeff, 01-07-2003 10:18:03
Sounds like the front end except the radiator goes with the engine.
