John..... .I flunked mind reading, just ask my ex-wife. Frontmount or Sidemount distributor? 6 volts or 12 volt conversion? These all make a big difference in what and where to check for lost sparkies. If ya' gotta change the coil, then ya' gotta have a reason. The voltmeter will tell you the reason. A voltmeter is a "BIG HELP" in diagnosing electrical problems like this. $20 or less at the local mega-hardware supermarket, get one. Trace your ignition electrics with the voltmeter until the volts disapear, then fix the offending part. Its amaizing, that tractors can set for months and suddenly not work. Generally, some corroded connection somewhere. Tighten 'em all, make certain all the wires are good and tight (try to pull the wire out) in the wire terminal sleeves. Skunch 'em up tight with pliers. Oh by the way, one of the original founding member of this great N-Board used to claim that 80% of all carburator problems were found in the ignition system. Something to think about..... ....Dell
