Order Ford 9N Parts Online
9n wont start
Terry L.Steeves
12-19-2000 19:41:51
changed and gapped plugs al-82s.Replaced cap and button,Replaced carb gaskets.Getting gas to intake but does not seem to reach plugs.Checked compression 1,3&4 are at 115-120 2 is at 90 .If i hold my hand over carb or choke,it will fire but not run.This tractor ran like a dream since i got it 3 years ago.Iwas running it at a low idle when it started running rough like one only 2 cylinders then quit.It would not start after it quit.Also it is geared for 12volt but seems to have good spark.any input would be greatly appreciated.
Bill in Houston
12-19-2000 19:52:37
 Re: 9n wont start in reply to Terry L.Steeves, 12-19-2000 19:41:51
Terry;
I had something like that this summer. had to crank it at a high idle, use lot's of choke. It drove me crazy. The only thing that didn't make sense was- If I choked it by putting my hand over the carb intake, it hardly had any suction. I remembered it having a pretty good draw. Finally, I bought a new manifold and installed it. It has never run this smooth. You might try placing your hand over the intake
Good luck and Merry Christmas
Bill
stick
12-19-2000 19:49:38
Sounds more like a fuel problem. Check all your fuel filters, clogged etc.. Will it start with ether?? If so, then fuel issue.
Terry Stevens
12-19-2000 19:43:57
Also set points for .015 they were off but still wont start.Help
