Leaky gas tank
smack
01-04-2003 18:19:50
I know someone posted a solution for a leaky tank a while ago but I neglected to right the URL down ... I believe it was a product called POR? Can anyone help/suggest a remedy ...
Thx.
JMS/MN
01-04-2003 22:35:12
 Re: leaky gas tank in reply to smack, 01-04-2003 18:19:50
Johnson Gas Tank Sealer. Check with radiator shops.
Wisconsin
01-04-2003 22:05:50
My chainsaw gas tank leaked a few weeks ago. I emptied it and used a product with the word Aluminum in it. Not sure what it was called, but it is sold by Fleet Farm. I applied it to the hairline crack on the exterior of the tank after sanding the paint off. No leaks since the application.
MikeC
01-04-2003 18:30:02
POR 15 makes a sealer for the interior of the fuel tank to seal rust off. It won't seal holes though. For that you will need to get it welded or use a regular fuel tank hole sealer. I'm not sure if something such as JB Weld can be trusted on a fuel tank directly over a hot engine-I don't know if it will work in contact with gas.
smack
01-04-2003 18:35:19
 Re: Re: leaky gas tank in reply to MikeC, 01-04-2003 18:30:02
Mike .. thx ... i can't see any holes, rather it seems the tank is 'weeping'(if that makes sense) and I thought it might make sense to try the sealer before replacing the tank.
Thx again,
Steve
Mountainman
01-04-2003 22:42:03
 Re: Re: Re: leaky gas tank in reply to smack, 01-04-2003 18:35:19
Eastwood also makes a gas tank sealer. It involves using a series of chemicals to clean out the tank and then seal it up - I used it on my 8N several years ago and no problems since.
hth
Mountainman...CA
