12V battery for NAA
NAA-HVC-IOWA
12-19-2000 12:36:56
I need to replace the battery in my Jubilee 12 Volt. Can anyone recommend the maximum cold cranking AMP rating to use that will not be too hot for the rest of the electrical system?
Jimp CO
12-19-2000 12:48:38
 Re: 12V battery for NAA in reply to NAA-HVC-IOWA, 12-19-2000 12:36:56
The CCA has nothing to do with your system per say.
All the Cold Cranking Amps tellyou is the amperage that the battery is capable of putting out whenit is at the rated cold temp, which may be 0 deg or -20 deg.
I would recommend getting one that has at least 850 CCA. This will give you plenty of cranking power(amperage) when you need it.
The "Work Horse" from Interstate has 900CCA and it is in a 449N. Never a problem. I use the same battery in 2 of my Willys and they work fine here in cold Colorado to.
HAA-HVC-IOWA
12-19-2000 12:59:02
 Re: Re: 12V battery for NAA in reply to Jimp CO, 12-19-2000 12:48:38
Thanks!! I have had good luck with Interstate batteries in the past also... I will go with your recommendation.
Jimp CO
12-19-2000 13:11:13
 Re: Re: Re: 12V battery for NAA in reply to HAA-HVC-IOWA, 12-19-2000 12:59:02
I put NEW interstate's in my 96 Ford Diesel when it was only 2 years old.
There was nothing wrong with the batteries in it , but I have never had a problem with the Interstates and that diesel requires some cranking power on -10 deg. mornings.
