Liquid in wheels
Larry
12-19-2000 07:54:32
Howdy! All this talk about the liquid in the wheels now has me concerned. When I got this 9n the seller said there was some sort of liquid in the wheels for traction. I didn't know it would damage anything. How much can I expect to spend for wheel weights? Are they easy to install? Should I just have the tractor repair guy remove the liquid and install the weights? I also noticed that the rear tires are slightly different sizes! Just spent a small fortune on it doing the brakes and a few other things. Thanks!
Lazyhorse
12-19-2000 08:00:08
 Re: Liquid in wheels in reply to Larry, 12-19-2000 07:54:32
If the air is staying up in your tires, I wouldn't worry about taking the fluid out. The big reason Calcium Chloride rusts so bad, is people dont repair leaks soon after they happen. Just keep an eye on your tires, and you'll be fine.
Hilltopper
12-19-2000 08:04:36
 Re: Re: Liquid in wheels in reply to Lazyhorse, 12-19-2000 08:00:08
Weights can be found for about $200 in the Ads section. I remember that our old F-20 had concrete weights bolted with J hooks. They were very slick and painted aluminum. Poor man's tractor weights!
