Order Ford 9N Parts Online
12V conversion of 9N
INCase
12-30-2002 07:46:16
We have the bits and pieces to convert our 9N to 12v alternator. with going to neg ground will the starter turn the wrong way or does it care?? Thanks
Jim Spencer S.E. Michigan
12-30-2002 07:48:21
 Re: 12V conversion of 9N in reply to INCase, 12-30-2002 07:46:16
Starter don't care.
Starter and starter switch will be O.K.
Dell (WA)
12-30-2002 08:23:53
 Re: Re: 12V conversion of 9N in reply to Jim Spencer S.E. Michigan, 12-30-2002 07:48:21
INCase..... ...what Jim said..... ..and..... .
Ammeter don't care (kinda) but you care. Ammeters traditionally indicate (+) for chargeing. When you change to negative ground the ammeter will indicate (-) for chargeing. (which messes up peoples head) Change the way the ammeter wire is connected to make it read (+) when chargeing.
Headlights don't care, but you care. 12 volts on 6 volt lights, mak'em go poof. Respect the dark sucker theory. (grin)..... ...Dell
