BAD DAY !!!
DAVE S.
12-29-2002 15:23:20
I decided to fix that rear tire on the 8n today because of the calcium leak had me worried. I knew it was going to be a task,butit had to be done.So in trying to save time I used my backhoe to break the bead on the other side because it was a little tough.I guess I wasn't paying close enough attention but I put two of the backhoe teeth right through the side wall. ERR!! If that's not bad enough the rim rusted through half way around too.
BS@ElmaNY
12-30-2002 05:51:16
 Re: BAD DAY !!! in reply to DAVE S., 12-29-2002 15:23:20
Dave:
Sorry for your problem. I usually swear and throw tools when I do something like that... which is usually every time I do something!!!
As I said in a previous post, I'm guessing that windshield wipers and tire tubes are made of the same rubber... straight natural rubber. I haven't heard where natural rubber has been replaced with synthetics (as someone stated in that same previous post). There are many, many different rubber compounds, and natural rubber is about the cheapest. It also has the poorest physical properties... low tear, poor chem resistance, etc. I used to design Air-Paks, so I'm somewhat familiar with rubber compounding, selection and testing. If you ever wore a Scott Air-Pak, you've seen some of my design work. I developed much of the flame & fire resistant materials on the Air-Pak's that were first accredited to the NFPA-1981 standard.
I think if windshield washer juice is OK on wipers, it should be OK on tubes. Flammability is a concern. If so, then I have to guess that there are some solvents that off-gas from the stuff. That concerns me. I don't know what the blue juice does over time. That is, does it break down, etc.
I'm conservative, so I would really recommend against using blue wiper juice in your tire tubes. I just don't know what the long-term possibilities are. Could the tube rubber compound be attacked over time? Could the blue-juice solvents off-gas over time through the tube? Remember, just because air doesn't get through a rubber tire tube over time doesn't mean that a solvent molecule can't.
If tire rims are cheap, I'd stick with the tried and true calcium. Or, wheel weights, to me, would be ideal.
That's just my 2�.
Bri
JJ
12-30-2002 05:16:30
Windshield washer fluid is flammable, but some guys around here use anti-freeze. Not as cheep but just as good. Remember to mix it with water. Most anti-freeze will freeze if not mixed with water. If you are in a very cold area, mix it and test it down to your climate.
duey
12-29-2002 18:51:57
Dave, check with Tucker Tires.... I think you can get wheel, tube, and tire as economically as possible. Ask for the ply rating you want, 4 or 6.
Nice to have it shipped direct to you.
Crispy
12-29-2002 15:50:44
Expensive day. I have read different responses to fluid in the rear tires, but after spending close to $600.00 for tire, tubes and rims, I am all done with salt water. Chains are cheaper and ya can always find something for weight. Just my $600.00 worth.
/Crispy
richard
12-29-2002 16:38:04
 Re: Re: BAD DAY !!! in reply to Crispy, 12-29-2002 15:50:44
I know what rims cost, when i bought my 2n we had to haul it about 140 miles and everything was ok when we loaded it but when I got it home it had two flat tires. the rims were rusted out from the calcium and collapsed, taking out the tubes with the rims. the tubes were rotten from the calcium.
I now have two new rims and tubes and a set of chains. if I have to load the tires I will use antifreeze.
Dan
12-29-2002 17:18:02
 Re: Re: Re: BAD DAY !!! in reply to richard, 12-29-2002 16:38:04
A guy at work told me he uses windsheild washer fuild .... the blue stuff you see at the gas station... anybody heard of this?
Dan
jim herrick
12-29-2002 20:01:52
 Re: Re: Re: Re: BAD DAY !!! in reply to Dan , 12-29-2002 17:18:02
i just got done buting windshield washer fluid in my 8n rear tires, replaced one rim [from calcium]each tire took 30 gls.wallmart had it on sale .75 a gal.cheaper than new rims.works great.
Dan Youngs
12-30-2002 04:14:34
 Re: Re: Re: Re: Re: BAD DAY !!! in reply to jim herrick, 12-29-2002 20:01:52
How do you get it in the tires...
jim herrick
12-30-2002 19:21:11
 Re: Re: Re: Re: Re: Re: BAD DAY !!! in reply to Dan Youngs, 12-30-2002 04:14:34
use a floor jack to raise the wheel, then get a clear hose to fit over the falve stem [ take out valve core and the air]find a fitting to hook the hose to a gal. plastic container cap. cut a hole in the bottom of the container and use a wire to hang it 4-5 feet above the wheel.lower the tractor to compress the tire,start in the first gal. ,raise the tractor a little and it will suck it in,takes a while but works well,just continue after each gal or two let it down to let the air back out and repete same over again.fill till liquid is up to about 11 oclock [relation of the valve stem from top center]
Al
12-29-2002 20:13:39
Windshield washer fluid is flammable!!!!Be careful.
