Order Ford 8N Parts Online
8N Ford Tractor Not Getting fuel through intake
Jimmy
12-29-2002 14:38:53
I have a 1948 8N with front mount distributor. Just had engine rebuilt after purchasing, put engine back on had problem getting engine to fire at first corrected that problem. I have switch intake off of my other 8N that was running. Had to put gas in each plug hole to get it to run it runs until that fuel runs out. Also, checked compression over around 100lbs on each cylinder.
If you guys have any suggestions please email
Thanks,
Jimmy
Gordon
12-29-2002 17:26:23
 Re: 8N Ford Tractor Not Getting fuel through intake in reply to Jimmy, 12-29-2002 14:38:53
Check the carb Float valve. If it has a rudder tip and a knob on the end with no wire hooked to the float.This could be your problem. Sometimes the float valve will stick and the float should pull the valve open. Check fitting in carb it sometimes has a screen on the end that could be pluged.
Capt Jack
12-29-2002 14:52:44
Jimmy, I know this sounds trite yet..have you checked to see ifn the fuel is leaving the tank?
Remove the line from the shutoff valve and sediment bowl with the valve off...then take a can (so you can catch the fuel) and turn the valve on...turn it all the way to reserve just in case you have a clog in the main. If you have fuel, then have you checked the fuel filter in the carb? It is a tiny screen where the fuel line comes into the carb. Give that a check and then let us know what you found.
Have a Safe New Year
capt jack
dw racing
bg
12-29-2002 14:48:35
Check the fuel filters at the tank, and in the carb inlet elbow. Make sure the tank vent isn't clogged(or open the gas cap 1/4 turn.) Does this have the OEM steel fuel line or has it been modified with rubber or copper or an inline filter? Open the drain on the bottom of the carb. The fuel should have a strong flow. If it does, then you have a problem in the metering jet. Clean the carb thoroughly with solvent and compressed air blown through anything that looks like a hole inside the carb body.
Finally, make sure you have a good gasket set on the manifold and it is properly torqued.
cleo stockwell
12-29-2002 18:28:05
 Re: Re: 8N Ford Tractor Not Getting fuel through intake in reply to bg, 12-29-2002 14:48:35
hello I would check timeing on the motor. A new motor should have 140psi comp. hope this will help.
