3 Point lift lever
Kevin F(Ohio)
12-27-2002 18:52:58
Only got half the drive plowed with the old 2N when lift lever snapped off about 6inches from top. Tried welding it but it appears to be cast. Weld wont take. Where can i get one besides New Holland? Or can it be repaired? Thanks for any help.
hobo NC
12-28-2002 04:17:08
 Re: 3 Point lift lever in reply to Kevin F(Ohio), 12-27-2002 18:52:58
I have one let me know if you need it
Levi(WA)
12-27-2002 23:12:19
If its the lever that broke there is 2 bolts that hold it to the friction plate, you should be able to jury rig it till you can replace the lever.
I have any of those parts you might need, post your e-mail and I'll contact you, if you like
OH Boy
12-27-2002 19:09:52
Which part is it exactly that is broken, the lift arm that attaches to the implement, or the arm that comes off the shaft at the top of the differential.
If it is the lift arm, Tractor Supply Company carries them.
If it is the other arm, there is a tractor salvage place in Bluffton Ohio called Anderson Tractor or something like that that would probably have a used one. I found their number once by searching on the internet, don't have it handy right now.
Kevin F(Ohio)
12-27-2002 19:36:50
 Re: Re: 3 Point lift lever in reply to OH Boy, 12-27-2002 19:09:52
I should have said that it is the control lever. The one beside the seat that you pull to raise and lower the 3 point.
Ultradog MN
12-27-2002 20:14:26
 Re: Re: Re: 3 Point lift lever in reply to Kevin F(Ohio), 12-27-2002 19:36:50
There's one on ebay right now.
Just happened to see it.
I have nothing to do with it.
Good Luck
Kevin F(Ohio)
12-27-2002 19:35:48
