Judy..... ..... what bg and Willie said..... ..and..... CAUTION: don't let the long bolts/screws of the starter come all the way out 'cuz yer starter will fall apart and the brushes can be a real PIA to put back in their holders (its a trade secret but I use wooden toothpicks). I use some 5/15 NC (coarse thread) nuts to keep the starter from falling apart as I wiggle it around past the flywheel ring gear. The starter Bendix drive screw has to be squeekie clean, no oil or greese. Made to operate with no lubrication. Installation is a reverse of the removal. Except..... .remember the 6 volt mantra: "keep'em clean, bright, and tight". And don't be fer using enny of them thar wimpy 12 volt battery cables. Use 'airy chested 1/0 (thick as yer thumb) 6 volt battery cables. And I recommend having your starter rebuild by a real automobile electric shop, (look in yellow pages) its cheaper. Then get a new CLUTCH type starter drive, much better than the old Bendix drive. If you have any questions, please ask, we care..... ...Dell
