Order Ford 8N Parts Online
8n hydraulic oil?
Bob
12-22-2002 20:34:11
Has anyone used 85w140 oil in the hydraulic sytem of thier 8n. Thinking of putting it in mine, the tractor won't be used in temps colder than 60 degrees. How good does it work? Thanks Bob
MikeC
12-23-2002 06:47:44
 Re: 8n hydraulic oil? in reply to Bob, 12-22-2002 20:34:11
I have been using the 134 spec for nearly 2 years now with no trouble. My 3pt holds up my finish mower (about 350#) with no trouble. I'd make sure that all of the seals were in good shape first. If you want to use something slightly thicker then I would recommend that you follow Dells advice on the 90W.
dave#1
12-23-2002 06:10:15
I also used the 80w90 weight in my 8n, I've since changed to the 134d oil which I hate, The hydraulics now make alot of noise and are much slower, My next oil change I'll be going back to the 80w90. It's been said that the 80w90 will ruin the trans,rearend and hydraulic pump, I think this is like compareing apples to oranges or compareing N series tractors to BMW's (Which some have done)Our tractors are low horse power machines which most of us use for mowing grass ,plowing alittle snow and a place to set our beer cans when we're in the shop or cooking out, I don't think or feel 80w90 will hirt(or ever heard of it hirting)our N series tractors trans,rearends or hydraulic pumps.
I accept complete and sole responsibility for the words and images contained within my post and accept complete responsbility for any resulting lawsuits, including but not limited to libel, slander, personal injury, copyright infringement and plagiarism. If what I'm about to publicize might be found offensive, I may want to reconsider, have a beer and/or consult a lawyer or circus clown before proceding
I.E..... Lets all lighten up !
Have a good one.
later"belch"dave
Salmoneye
12-23-2002 07:10:20
 Re: Re: 8n hydraulic oil? in reply to dave#1, 12-23-2002 06:10:15
I ate all the brass in a T4 Jeep tranny about ten years ago when I put in 80W-90W, cuz I just could not understand why the manual recommended ATF for a 4 speed manual when I changed the fluid...ran really quiet...for the first couple years that is...
Straight 90 weight EP gear oil is easily available at places like CT, and I have even seen it at WalMart...comes in 5 gallon pails for $25-$30...Even says right on the label, "For Use In Older Ford Tractors"...
I am running this stuff in my T5 tranny on my present Jeep...None of the addatives that eat brass and rubber in it...
I HAVE to run the M2C-134D spec in my 8N if I want to be able to use my tractor at all in the winter here...the 90W was thicker than molasses at 0 degrees and I spent more time trying to warm the tranny and hydraulics than plowing snow...
All of this is my opinion, and in no way reflects what others may have found in their experiences, manuals, or their underwear drawer...
Batteries Not Included
Objects In Mirror Are Closer Than They Appear
Ultradog MN
12-23-2002 04:41:49
I used 80w90 gear oil when I rebuilt the lift piston in my 2N last year. It would hold a heavy disc up all day and night.
But this fall I was having problems with it not lifting (as per Zane it was a sticking control valve) so I flushed it out with kerosine and refilled it with spec 134D that I bought from the dealer.
Now it leaks a lot more and wont hold an implement up nearly as long.
Les, TN
12-23-2002 02:11:07
I daily drive by and trade with a local Mobile wholesaler. Is there a Mobile equivalent to the M2C-134D?
NO ! NO ! NO ! ! ! . . . Dell (WA)
12-23-2002 00:36:25
Bob..... .....while you can use the 1939 9N hydro/tranny oil spec was 90wt mineral gear oil (if you can find it), Ford/New Holland now recommends Ford spec: M2C-134D hydro/tranny oil. 3 drains. Drain sq diffy plug first, then 2 1/2 hydropump, then 2 1/2 tranny, 1 fill up by tranny shifter, 5 gals.
85w-140 oil has unfriendly additives to your hydraulic system. Using thicker hydraulic oil to "bandaid" a sick hydraulic pump system is gonna make your tranny a stiff shifter..... ....Dell
Bill S TX
12-23-2002 06:23:41
 Re: Re: 8n hydraulic oil? in reply to NO ! NO ! NO ! ! ! . . . Dell (WA), 12-23-2002 00:36:25
OOPS. My bad.
Bill
Bill S TX
12-22-2002 20:38:55
Haven't used it there (transmission of a tractor), but down here in south Texas, it is common practice to use 85w140 or even heavier, such as Cotton Picker Spindle Lube in gearboxes on bush hogs and such, and even in manual transmissions on the farm trucks. The spindle lube is almost as thick as grease out of a grease gun at 70 degrees, but after a shredder has been running 20 minutes, it pours like water. We have some 20 year old bearings that have been running in that stuff...
FWIW
Bill Priday
Portland TX
