3-point lift does not come all the way up
Gary
11-18-2002 17:01:23
52 8n 3-point with back blade will raise some and then it kind of surges trying to go up further. I thought this was all the way up until I reversed my back blade. And in doing so I was lifting and trying to turn blade and noticed that it had come up about another 8 inches. I got it to do it on its own a couple more times, ( took awhile) now it won't come up any further than before. It does not creep down with the back blade on it.(heavy)I checked the archives but could not find any thing or else I looked over it. Any help would be appreciated thanks
ZANE
11-19-2002 05:32:23
 Re: 3-point lift does not come all the way up in reply to Gary, 11-18-2002 17:01:23
It is possible that the cam follower pin is worn out and needs to be replace and the lift re-adjusted at the same time.
Also the control valve coule be trying to stick but this is less likely.
See the link below.
