Is this safe?
Bert 1947 2N
11-14-2002 13:40:44
Yes, I know about drawbar locks and swinging drawbar assemblies (Don B has 'em), but I'm cheap/frugal.
So I did this.
I put a ball hitch in the middle hole of my 11 hole drawbar. I hitched my 4X8 trailer to the ball To keep the drawbar from rotating I took the double nuckle toplink thingy (what's that called?) and put it on the draw bar with a 1/2" pillar pin and a linchpin.
I disengaged the lift/pto.
Everything's level.
It seems to be stable, with no undue strain on any parts.
IS IT SAFE ?
Evil Steve
11-15-2002 07:50:07
 Re: Is this safe? in reply to Bert 1947 2N, 11-14-2002 13:40:44
I use the same set-up, but with a "drawbar lock" ($20 at FNH) to keep the drawbar from rotating.
I move my 20" bayboat and a utility trailer with building materials in it with my tractor. No problems as long as you don't overload the drawbar. Don't want her rollin' over on ya.
gene n ky
11-15-2002 04:03:21
won't the hitch rear up when backing up, or if you have more weight at the back of the trailor. gene
Salmoneye
11-15-2002 04:08:25
 Re: Re: Is this safe? in reply to gene n ky, 11-15-2002 04:03:21
If I understood his description correctly, the 11-hole drawbar can not rise or fall because the toplink is securing it...
Dave OH
11-14-2002 23:27:22
I really beleive in safety chains, just in case.
Dave OH
DON TX
11-14-2002 17:24:23
What's a 1/2" pillar pin? Got a pic?
DON TX
DON TX
11-14-2002 17:19:21
DON TX
Salmoneye
11-14-2002 16:59:35
Dunno...but my guess is pretty safe as long as you do not overload that trailer behind the rear wheels, push in the clutch on a steep hill, and have a flat in the front all at the same time...
I admire the ingenuity and doubt not that if a 1950's poor dirt farmer had thought of it, they would have done it too...
BG of course put it way more succintly...
Only.............bg
11-14-2002 13:58:14
...as safe as the nut that holds the wheel. ;^)
