Marconi..... ...guess what?, the reason your frontmount 6 volt tractor starts when cold but not when hot, is because you have a bad 6 volt frontmount coil. When it gets hot, the insulative tars melt inside the coil and short out some of the coil windings and now you don't have enuff sparkies to start when hot. Amazingly enuff, it "cures" itself overnight when it cools off. Replace your BAD 6 volt coil. And specifically, yes, 12 volt alternators absolutely DEMAND negative ground. Have you even considered doing a little research in the N-Board Archives at the top of the page about the trials and tribulations of the electrically challenged trying to convert to 12 volts? Read'em and weep. But if you are ABSOLUTELY bound and determined to convert to 12 volts. And if you are absolutely certain that you have one of those new 12 volt frontmount coils, then DO NOT USE the "infamous ballast resistor" on the backside of your dashpanel with the 12 volt coil. Understand? Use my secret tricky 12 volt conversion resistor instead, it'll make your 12 volt coil last a long time. Make a 1/2 ohm 10 watt current limiting resistor from a Radio Shack 2-pack 1 ohm, 10 watt resistor (p/n 271-131). With the resistors side-by-side, create a parallel resistor assembly by twisting the resistor wires together. Solder and terminate and install this new current limiting resistor inplace of the ballast resistor. Understand? ..... ..... .respectfully, Dell
