Order Ford 8N Parts Online
8N Rear End
larry patterson
11-09-2002 20:25:25
I have an 8N that does not have positive trac. but the rear wheels are locked togeather. It takes about 10 acres to turn around. Has anyone has this problem before, if so how to solve this problem. Thanks for any help
ZANE
11-10-2002 04:14:54
 Re: 8N Rear End in reply to larry patterson, 11-09-2002 20:25:25
Willy is right!
There us something locking up the differential gears. Probably expensive stuff broken.
Willy-N
11-09-2002 20:56:46
Sounds like the cluster of gears in the center has either locked up or got a rivit from the ring gear jamed in them. You should pull the left trumpet and pull the rear differental out to inspect it for damage. Mark H.
