2n will only idle
Mike
12-15-2000 17:04:59
I need some help on my 2n.The tractor was running fine and just quit and would not restart.So I started checking it out so far I have replaced the coil, spark plugs, spark plug wires,12 to 6 voilt resistor,dis.cap.Replaced wire to the distributor and rebuilt the carburetor.Cleaned gas tank and all lines.It will start now after I crank on it for a while.But all it will do is idle it will not power up I have good blue spark.The carburetor bowel is full of gas have good gas flow to the garburetor. Comp. is at least 95 to100 lbs per cylinder.It seems to have plenty of suction at the carburetor air intake and I checked the plugs and they dont looked flodded I have run out of ideals any suggestions.Thank you
Did you get it fixed????
12-17-2000 09:48:51
 Re: 2n will only idle in reply to Mike, 12-15-2000 17:04:59
MIKE
12-17-2000 15:44:43
 Re: Re: 2n will only idle in reply to Did you get it fixed????, 12-17-2000 09:48:51
NO NOT YET. THE WEATHER HAS TURNED REALY COLD HERE .BUT AS SOON AS I CAN I WILL GET BACK TO THE TRACTOR AND LET EVERYONE KNOW HOW ITS GOING.
THANKS TO EVERYONE FOR THE HELP
Hilltopper
12-16-2000 14:42:58
Try opening up your points a little. Let us know what works!!
Hilltopper
12-16-2000 14:41:41
Brad
12-16-2000 07:09:32
Drop your exhaust pipe from the manifold and see if the problem goes away. Might be stopped up.
MIKE
12-16-2000 12:33:15
 Re: Re: 2n will only idle in reply to Brad, 12-16-2000 07:09:32
THATS ONE THING I HAVENT TRIED ILL TRY IT AND SEE WHAT HAPPENS THANKS
Nolan
12-15-2000 19:53:01
Mine does that to - each time the throttle linkage falls off. Before you keep on spending money throwing parts at the tractor, find out what's wrong first.
Steve IA
12-15-2000 17:29:10
I would first double check the linkage set up. If it's correct, try disconnecting all the linkage and working carburetor by hand. If it works that way then you have linkage problems. if not, sounds like maybe something not quite right with carb rebuild. I'd check there. Good luck. HTH Steve 8n 169302
MIKE
12-16-2000 05:49:19
 Re: Re: 2n will only idle in reply to Steve IA, 12-15-2000 17:29:10
I have checked the linkage by working it by hand .I also took a carb off a tractor that was running fine and it does the same thing will only idle. THANKS
Dell (WA)
12-16-2000 17:42:38
 Re: Re: Re: 2n will only idle in reply to MIKE, 12-16-2000 05:49:19
Mike..... ...if I understand what you have just said.....a good working carb from another tractor does not work right..... .Then the logical conclustion implies that you have a GOVENOR problem because the governor really controls the carb throttle shaft.
Check your governor out..... .Dell
Hilltopper
12-16-2000 06:52:45
Does it run smooth at idle and start easily? It sounds like the timing gears have jumped but I don't know how that would happen with gear drive. Is your manifold good? Does it backfire when trying to speed up or just bog down or do nothing? Is the power valve clean? Is the ignition switch good?
MIKE
12-16-2000 12:42:47
 Re: Re: Re: Re: 2n will only idle in reply to Hilltopper, 12-16-2000 06:52:45
IT IS HARD TO START BUT WHEN IT DOES START IT RUNS SMOOTH.WHEN I TRY TO GIVE IT GAS IT DOSENT DO ANYTHING NO MATTER WHAT I DO TO THE CARB ADJUSTMENTS.AS FAR AS THE SWITH GOES I HAVE TRIED BYPASSING IT THANKS
