LOCKING REARS
Blitz
11-05-2002 16:11:20
Does anybody know of a system that fords used to lock the rear wheels??
My buddy said he saw an old ford with a little foot peadel on the right that went down to the bottom of the rearend and lock the rears! Anyone ever see this??
Ken.Fl
11-05-2002 19:49:32
 Re: LOCKING REARS in reply to Blitz, 11-05-2002 16:11:20
Fordson had a locking rear end on their Super Dexta (available here in the U.S. as Ford 2000 Diesel) back in 1962. It may have been available even earlier on the smaller Dexta.
Jim.UT
11-05-2002 18:06:25
I looked at a '74 Ford 2000 that had a differential lock....small pedal on the right side. I don't know when that feature became available.
dw
11-05-2002 17:04:30
Applying the brake on the spinning wheel has the same affect. The other wheel than starts pulling.
Dave Smith
11-05-2002 17:28:14
 Re: Re: LOCKING REARS in reply to dw, 11-05-2002 17:04:30
Not realy, When you hit the brake it just transfers drive to the other wheel. When you lock the diferental both wheels drive. If you get both wheels spinning and not digging and moving, You are stuck. Don't burry you're self. How do I know this? And it takes a bigger tractor to get you out. How do I know that. I have called myself a dumb s*** a couple of times.
Dave <*)))><
Dave Smith, PS
11-05-2002 17:30:46
 Re: Re: Re: LOCKING REARS in reply to Dave Smith, 11-05-2002 17:28:14
And when that happens, You have to get help. Then everyone knows. You hear about it for a long time.
Dave <*)))><
Willy-N
11-05-2002 19:59:46
 Re: Re: Re: Re: LOCKING REARS in reply to Dave Smith, PS, 11-05-2002 17:30:46
Dave I was doing some grading with the MF135 and snaged a rock. One tire started spinning. No problem I have a diferental loc! So I pushed in the clutch Locked it and let out the clutch and both wheels spun and dug holes so fast that they were spinning in free air with rear end sitting on the ground. Had to Lock the hubs on the truck and use Low Range to pull it out. Best part I did it by my self. Problem was I forgot to put something to stop the tractor after it got out of the hole! Had to keep driving the truck to keep it from hitting it and allmost ran out of driveway! Mark H.
Dave Smith
11-05-2002 17:04:08
Our 1975 5000 and 1980 1100 have a diferential lock. Great for added traction. But under a load it will stay locked and it will not turn with the front wheels. You have to stop and let the load off the diferential or it keeps going straight.
Dave <*)))><
Willy-N
11-05-2002 17:02:54
My Massey Ferguson 135 has the Locking Differental on it and it is a little pedal on the right. Mark H.
schultz47
11-05-2002 16:58:46
That was a Ferguson your buddy saw. They had the locking differential.
Some newer Fords(New Holland)..............bg
11-05-2002 16:38:47
... including some of the imported Oriental models, have a differential lock. I've never seen one on an N or hundred series.
duey
11-05-2002 16:16:36
There is no provision for a differential lock I've ever seen on an 'N'.... but it would be a great option to have on any tractor.
