Clint..... ....Sometimes when dealing with the electrically challenged, you need to ask if they understand, understand? And special for Clint, (since you didn't include an e-mail address), Ignition coil theory 101. Ignition coils work because of electro-magnetizm. The strength of the magnetic field is dependent upon many things, principally electron current as measured in amps NOT VOLTS. But Ohms Law conviently allows us to infer amps by measuring volts dropped across a resistance. Understand? The "infamous ballast resistor" was Ford's attempt to compensate for effect of cold temperatures on the poor quality of wetcell batterys when trying to start a cold engine with 6 volts (they hadn't invented the diehard yet). The ballast resistor automatically reduces its resistance with cold temperatures. Which inturns increases the amps thru the coil (Ohms Law, you know). Which increases the magnetic field. Which increases the strength of the sparkies when the points open and the magnetic field collasps. Within about 90 seconds, the ballast resistor has heated up and increased its resistance and reduced the current to the coil primary before the coil has had a chance heat up and melt its internal insulative tars and short out the primary windings thereby causing weak sparkies. Read very carefully, I specifically called my trick 12 volt coil resistors "current limiting" 1/2 ohm 20 watts and that is exactly what they do for the 12 volt frontmount coil. So the correct 12 volt coil check should be about 11 volts max. The 12 volt frontmount coils used to be tagged 13.8 volts max, care to guess why? Guess what the 12 volt alternators put out? about 14.7 volts. Guess what 14.7 volts does to the 12 volt coil current? Care to guess what that extra current does to the coil? Now for all you newbie brousers. The square OEM 6 volt frontmount ignition coil used with the "infamous ballast resistor" works best if you can measure about 3.5 volts at the coil terminal (2.5 min, 4.0 max) with the points closed (engine NOT running) and battery volts with the points open. Any other value is going to give you sparkie problems. These voltages are also correct if you choose to use a 12 to 6 volt converting resistor in series with the ballast resistor in a 12 volt conversion scheme. ..... ..... .respectfully, Dell
