Order Ford 8N Parts Online
8N Original rim question
Dale McElheny
11-04-2002 16:11:56
I had to replace one of my original 8N rims with a new one. About a year too late with getting rid of the CaCl. Anyway, my original is 10" from OUTER edge to OUTER edge. I assume it is a 10 x 28. The new rim is a Ford rim (new style with the 6 loops)and says it is a 10 x 28, however, it is 10" from the INNER edge to the other INNER edge and 11" on the OUTER edges. Is this a change in the way rims are measured? Is this the best/closest I can get?
I know I will end up with a slight height difference using this, but I don't think it will be significant enough to matter. Any info would be appreciated.
Dale
Scott
11-04-2002 18:23:01
 Re: 8N Original rim question in reply to Dale McElheny, 11-04-2002 16:11:56
They are measured at the inside of the curve at bead, all 28" rims on 9N, 2N, 8N and NAA's used the 9" wide rims, the new part# with the 6 loops is NCA1020C and the 10" wide is NCA1020B used on the 600 and up.
Dale M
11-10-2002 08:57:52
 Re: Re: 8N Original rim question in reply to Scott, 11-04-2002 18:23:01
Thanks Scott. I have the 1020B - need to get the 1020C.
Dale
