12volt conversion follow up
Fessman
11-03-2002 11:58:06
Yesterday I posted that I was getting 13+ volts out of the alternator, at about 600rpm. I ran it over 600rpm and the voltage went up to 14.8 volts. It seems that 600rpm (engine speed) is the cross over point. above 600 rpm it puts out 14.8 volts, below 600rpms it drops to 13.5 volts. Thanks to all.
Fessman
duey
11-03-2002 17:24:08
 Re: 12volt conversion follow up in reply to Fessman, 11-03-2002 11:58:06
Your alternator is doing mighty fine. Don't think mine will do that at 600 RPM...but I used a larger-than-automotive pulley. The large pulley keeps the belt from rubbing where it shouldn't on the block and at the same time lets me keep the alt. in close to the motor to avoid conflict with steering parts on rough ground.
You've got good numbers.
Dell (WA)
11-03-2002 12:05:03
Fessman..... ..those are pretty good numbers. Don't know why yer buddy can't keep his battery charged. Could be a bad battery?..... .Dell
Fessman
11-03-2002 14:15:46
 Re: Re: 12volt conversion follow up in reply to Dell (WA), 11-03-2002 12:05:03
Dell,
That was someone else who was having troubles with a buddy / neighbor's battery. The problem I was having was due to the alternator being shot.
Fessman
