2N Hydraulic pump
Guido
12-15-2000 10:55:48
I'm rebuilding my 47 2N and although the hyd pump was working I decided to dis-assemble, clean and refurbish. The manual says to replace any worn parts but does not give any wear specifications for the components. Only the pistons show any wear but is not excessive. Are there any parts that I should replace before assembly?
Also, has anybody ever tried to retrofit a modern pump in an N-series to replace the current pump and run remote hydraulics?? Looks as though there is enough room to squeeze something in.
Great forum and thanks in advance for all replies!
TimK
12-15-2000 13:45:20
 Re: 2N Hydraulic pump in reply to Guido, 12-15-2000 10:55:48
Since the pump was working ok, I'm not sure you want to invest $200+ in a rebuild kit to replace the guts like the cam blocks, pistons, etc. Probably what you're looking for is a good cleaning out including inside the tractor housing, blowing out the pump and the hydraulic channel in the bottom of the pump with air, new gaskets and relief valve and that's it ! That will cost you about $40. I'd also put in new oil 85-90 wt. which is another $35.
