Order Ford 8N Parts Online
1950 8N hydrolic touch control lever
Vic gabrenas
10-30-2002 16:09:49
Hydrolic touch control lever is stuck in the up position. Forcing it will require enough pressure to brake it. It worked fine this summer. The position control lever works fine. the tension spring is loose and not the problem. Thanks to anyone who can help.
Vic
Ol Coot
10-31-2002 03:14:40
 Re: 1950 8N hydrolic touch control lever in reply to Vic gabrenas, 10-30-2002 16:09:49
I THINK that the only way to check out this is pull the top plate assembly off for an eyeball inspection. After being into mine a few times, a guess might be a broken spring/plate or linkage pin
