Order Ford 8N Parts Online
8N cracked oil pan, fix or replace?
CWilcox
12-14-2000 19:25:20
During overhaul found a 4 inch crack that goes through the 2nd bolt hole from the front right and it goes down about 4 inches toward the bottom of the pan. Is there a good fix or should I just find a good used one???
AL@NC
12-15-2000 06:09:00
 Re: 8N cracked oil pan, fix or replace? in reply to CWilcox, 12-14-2000 19:25:20
I welded one on a 9N. Easy to do, can't imagine it costing too much. Just make sure its good and clean if you take it to a welder.
Scott
12-14-2000 23:27:46
There's a pan on Ebay for $85.00. Keep an eye on it, add freight, then compare it to the repair estimate from your local shop. After you flip a coin, you'll know what to do.
Scott
Bill (in Colo)
12-14-2000 20:42:09
When we got our 9N, it's pan had cracks that had been brazed (brass).
It looked like a nice job and has worked
fine for the many years we have had it.
JimNC
12-14-2000 20:15:45
Take it to a machine shop and get it welded. Ask how much it will cost, try to get it in writing. Had my block welded, asked how much the man said around $250.00, well got the bill today $614.88. Hope this helps.
Rick/Kansas
12-14-2000 19:53:35
I purchased an 8n this past summer from a neighbor. After removing about 1" of grease and dirt I found that the oil pan had a weld on it, in the same location you described. It holds OK, and isn't too noticeable. If yours can be repaired it would cost a lot less than another pan.
