Locking brakes solution
Dale McMillen
10-27-2002 05:12:12
When I rebuilt my 8n, I also did the brakes. The kept locking up when I drove forward. Even the Ford tractor dealer had never heard of it. I did two things. First I noticed that the shoes were rubbing the outside of the drum at the rounded corner. I ground a beval on the edge with my angle grinder and it helped one side but not the other. Then I read a post on this forum that suggested that the shoes were too thick. I noticed that there was excessive wear at the rear of the top shoe and front of the bottom shoe. I ground these two areas down and that has solved the problem. I hope this helps someone. I also had a fan going and wore a dust mask.
