Lift pole?
Jim
12-14-2000 07:18:08
I have a 9n with a blade on the back. Is there aney plans or pictures of some one has sompthing like this on the back of there 9n. What I want is like a moter puller. Onley using the 3pt lift. Thank you
Jim
Carl/PA
12-15-2000 15:48:35
 Re: Lift pole? in reply to Jim, 12-14-2000 07:18:08
Jim. TSC and Quality Farm and Country both have boom poles or cranes for 3 pt hitch. Not very expensive and will lift around 1000#
ZANE
12-14-2000 08:09:08
If you are planning on using a boom pole on the back of the 9N or 2N you should think about adding a position control device on the lift so it will be possible to hold the height at a selected place. Without the position control it is very hard to pull an engine etc with a boom pole because of the creep of the lift.
See the link below.
DavidO
12-14-2000 07:29:49
Check the link below. I have seen some others, but this is the only one that I have seen that looks heavy duty enough to pull an engine.
