3 pt. lifts slower the longer it's used.
Troy
12-14-2000 01:29:28
We got 12" of snow in Freeland, Michigan. I fired up the 51 8n to find the driveway. (I've only owned it a month) The 3 point raises fine when first started, after 45 minutes or so it slows down on the last 4" of travel up. After a couple hours it raises slower. The the hydraulic oil level is good. Not sure where to go from here. I don't know much(anything) about the system and my I&T FO4 manual is coming in the mail.
TimK
12-15-2000 08:01:21
 Re: 3 pt. lifts slower the longer it's used. in reply to Troy, 12-14-2000 01:29:28
I believe what's happening is that as your hydraulic oil heats up, it gets thinner and begins leaking around the gaskets, valves, rings, etc. in the system. Take a look at the archives n this Board and see Zane's responses to diagnosing hydraulic problems. Do that and read your FO-4 manual, and you might be able to find the problem.
Fred OH
12-14-2000 10:15:53
I'll just remind you to check the dipstick when the lift is all the way up. If you're doing it when it's down, it looks like it's full and it isn't. L8R----Fred OH
