Order Ford 8N Parts Online
8nw/dearbornfrontblade
Dan
10-21-2002 18:32:36
I just picked up an 8n with a dearborn front mount blade and the cables that raise it don't look like they are secured inthe right places. I am looking for a picture to compare. Any help would be appreciated.
Ed Gooding (VA)
10-22-2002 03:28:32
 Re: 8nw/dearbornfrontblade in reply to Dan, 10-21-2002 18:32:36
Hi Dan. See if this helps..... ...
Third Party Image
Third Party Image
Third Party Image
I have the full owner's manual for this implement. If you need more info, just give me a shout. BTW, the frame the blade is mounted on was called the "Universal Frame" by Dearborn, because you could attach a dozer blade, snow blade, and V-snow plow blade to it.
Hope this helps..... ..... Ed
'52 8N475798
Rod MI
10-21-2002 23:14:05
This link mite help could you if you post sum pictures of your setup someone mite be able to tell you if its right
Rod MI
10-21-2002 23:17:19
 Re: Re: 8nw/dearbornfrontblade in reply to Rod MI, 10-21-2002 23:14:05
Oops I thought you had an ARPS blade
