3pt quick connect
JT Hou
10-21-2002 11:14:23
Do any of you good folks have experince with quick connect 3 pt hitch. I have bad knees and have a hard time changing implements by my self. Climbing up and down 3 or 4 times I am worn out.
T 'N Tx
10-21-2002 18:40:26
 Re: 3pt quick connect in reply to JT Hou, 10-21-2002 11:14:23
Here's one in the Northern tool catalog.
I've never posted a link before, hope this works.
I'd like to hear from someone who has used these. Or is this just like the one mentioned from TSC?
looks like the same thing as TSC
10-21-2002 19:15:56
 Re: Re: 3pt quick connect in reply to T 'N Tx, 10-21-2002 18:40:26
third party image
Ultradog MN
10-21-2002 17:23:30
I probably shouldn't mention this on the N board but...
Doesn't the Fast Hitch system (Allis Chalmers?)
hook up so that you don't have to get off the tractor? Someone here will know for sure.
Scott.ID
10-21-2002 16:27:52
third party image
JT,
I bought one from TSC and modified it to fit on the front of my skid steer. It's nice to be able to use my N attachments on other things, but the Quick Attach is more trouble than it's worth.
The unit that TSC carries is listed for Cat1 and Cat2 attachments, and comes with a couple of small "sleeves" to reduce the hooks down to Cat1 size. You have to move the adapter sleeves from one attachment to another to get them to work. You also have to bolt/unbolt the sleeves in place so they don't fall out and get lost. It takes longer to switch from one to another than it does to grade the whole driveway.
My nickels worth,
Scott
Durk (OH)
10-21-2002 13:16:30
Someone posted this site here a couple weeks ago. Allows you to attach implements without getting off your tractor. it doesnt have a price, if you find out let us know.
Durk---Dave OH
10-21-2002 20:58:27
 Re: Re: 3pt quick connect in reply to Durk (OH), 10-21-2002 13:16:30
I wish someone would buy one and let us know how it works! I was just going to give him the same info as you did. Sounds good?
Dave OH
JT HOU
10-21-2002 13:56:23
Thanks Durk. Havn't seen that one. I have looked at the one Tractor Supply sells. I don't think it would be as easy at that one. It has a couple of latches you have to close after you pick up implement.
