Order Ford 9N Parts Online
'40 9n Brakes
00fxd
10-20-2002 20:08:51
I use my 1940 9n only in the winter for pushing snow. After sitting for the summer last year the left brake no longer worked. I was able to operate it thru last winter using only the right brake, it's only low speed operation. Now sitting for another summer the right brake does not work. The shaft seems siezed altho I can see that they are free in the bushings.
Help please!
00fxd
10-21-2002 15:54:43
 Re: '40 9n Brakes in reply to 00fxd, 10-20-2002 20:08:51
I guess I'll have to pull those wheels! Damn!
Thanks for all your input guys.
00fxd
10-21-2002 09:23:44
I ment to ask where to get a good general service manual for a '40 9n? I love my tractor and intend to keep it!
Dell (WA)
10-21-2002 10:52:38
 Re: Re: '40 9n Brakes in reply to 00fxd, 10-21-2002 09:23:44
00fxd..... ....I&T FO-4 manual readily available at most tractor parts emporiums, amazon.com, borders books, barns and noble, www.n-news.com (great archive of implement manuals), why even Ford/New Holland sells them, isn't that amazing? $29 cheap, gettcha 1 and readitt. The otherday, someone was claiming WalMart was selling it for $13.
To fix your sticky brake rods, yer gonna haffta pull yer brakes ennyways..... ...Dell
ED-IL
10-21-2002 06:24:32
Yup - sounds like fluid leaked onto your shoes...
third party image
Here is the right brake assembly from my 2N. Notice the trail of fluid on the backing plate. Notice a portion of the brake shoe closest is missing. Notice how the remaining shoe is black and oily.
My brakes had been adjusted per FO-4 manual (if you don't have one, get one) and it seemed as though the brake pedal had bottomed out.
New shoes and a couple of "sure-seals" will do the trick. Your parts suplier should have the parts.
DING
10-21-2002 03:32:03
You may find the oil from the rear end has creeped
down the housing and onto your brake shoes. 9N's
are notorious for this and the only way to fix
it is to remove the shoes and clean them. The trouble is, it will happen again.
Fast Ed Ohio
10-20-2002 23:50:24
Your gonna have to take them big wheels off and take a look, be carefull if they have fluid in them they could weigh over 300 lbs. , I would say things are rusted real bad or break shoes are shot.
00fxd
10-21-2002 09:12:24
 Re: Re: '40 9n Brakes in reply to Fast Ed Ohio, 10-20-2002 23:50:24
Thanks for the replies fella's. I had thought of oiled brakes but it seems that the brake rods rods themselves are stuck and not moving [rotating] at all.
Zeked
10-21-2002 14:09:58
 Re: Re: Re: '40 9n Brakes in reply to 00fxd, 10-21-2002 09:12:24
Double "0",
I had what seems like the same problem with my '45 2N.... "someone" had adjusted the brake adjustment to the max and there was no travel. Back off the square lug and see if you can get any that way. (That wasn't supposed to sound dirty>>>)
Zeke Duge
