Order Ford 8N Parts Online
8N Engine Block
Eddy
10-18-2002 03:41:53
Does anyone know where you can find a good used block? I just bought a tractor that I thought was running good, even drove it a while. When I got home with it saw a little slow weeping coming from the left side behind oil filter. After pulling the head saw it was cracked along the top of block into a water jacket. The rest of the tractor is in such good shape I hate to give up on it. Any help would be appreciated.
Levi (WA)
10-18-2002 10:00:28
 Re: 8N Engine Block in reply to Eddy, 10-18-2002 03:41:53
Eddy,
I've got a real nice 8N block, I sent you an e-mail.
jim
10-18-2002 07:40:13
I got a 2n that the block had a crack in it on the left side and I took it to the machine shot and they Piened it. I put it back together and it had a small leak at the end where they piened it so I used some stop leak. Runes like a new one with it is all restored. I use it to grade the road in to my place. Jim in AZ.
MikeC
10-18-2002 04:30:46
I agree with Mark. At least give the JB Weld a try before investing in a new block. You don't have much to loose with the old one, do you? While I have never used it on an engine block, I have used JB Weld for several other things and if you have never used it before you will be surprised at how strong it is.
Mark in Central Ohio
10-18-2002 04:23:20
Mine was the same way. Ran great but after I cleaned it up real good I found antifreeze leeking from an 8-10 in crack on the left side behind the oil filter and the starter. It leaked a couple pints after each use so I had to put a bucket under it in the garage to catch it all. Some on this forum suggested patching with JB Weld and some suggested welding. I went the JB Weld route. I've ran it several times pretty hard and it's held so far. I used a grinding wheel on the drill and gound out a "V" along the crack and cleaned the block good. Used several thin layers of JB Weld and sanded it down fairly smooth. Can't really tell any work was done.
Eddy
10-18-2002 04:57:45
 Re: Re: 8N Engine Block in reply to Mark in Central Ohio, 10-18-2002 04:23:20
Mark,
Was your crack on top of the block where the head gasket will seat? I heard a lot about the JB weld and was ready to use it on the side of the block but when I saw it on top I didn't think I would be able to get the head gasket to seat good. Thanks for any advice.
10-20-2002 09:44:40
 Re: Re: Re: 8N Engine Block in reply to Eddy, 10-18-2002 04:57:45
Eddy - the crack on mine was on the side. If it was me, I'd try the repair first.
REMMo.
10-18-2002 05:48:38
Some times its remarkable what J B Weld will do. As for the crack on the head gasket surface the head gasket should seal it. If you use J B on the surface where the gasket lays you can't leave any hump there and I wouldn't recomend grinding out a v there. I'd just try sealing the side like others have recomended and putting the head back on with a new gasket and a good sealer. If you only have a very small seep to the outside Bars Leak could be a very good remedy. I've had very good luck with it. REMMo.
