Order Ford 8N Parts Online
8N new points, timing problem?
Hooch
12-13-2000 08:19:00
I installed new points, condensor, cap and rotor this week. Kudos to all you mechanical geniuses who say they do it in 10 minutes. Taken me two days. I have a front mounted distributor. I set the #1 cylinder at the top of the compression stroke and removed the old points. I have everything put back together and the point gap set at .015 with a feeler gage. When I turn it over, it will not even sputter. Any suggestions?
ZANE
12-13-2000 16:10:54
 Re: 8N new points, timing problem? in reply to Hooch, 12-13-2000 08:19:00
I hope you took the distributor out of the tractor to replace the points. It takes a contorshinest and an old style printer who can read thing backwards to do it in the tractor and get it right too.
Take the dist out of the tractor and start from scratch. I'll bet you will find that you have something touching something it shouldn't be touching.
And like the man Claus said, be sure to check out the insulator for a short to ground where the little copper conductor etc. attach to the distributor plate. This is a problem spot when they get old. (They are all old)
hooch
12-15-2000 08:36:09
 Re: Re: 8N new points, timing problem? in reply to ZANE, 12-13-2000 16:10:54
Thanks Claus, Zane.
You were right. We put a dwell on it last night and found a huge voltage drop. Upon closer inspection we found that when I tightened the srcew that holds the condesor lead down, it turned on me and contacted the dist housing. Fixed it and she fired right up.
Zane,
I wished I had never attempted it while the dist was on, but now that I have I have become fairly good at seeing backwards through a mirror!
Claus
12-13-2000 08:30:29
Well, the first thing that comes to mind is that when you replaced the points, is that the insulator shorted out in the right angle bracket that is part of the point plate. It would be easy to check for this by using an ohm meter to ensure that when the points are open there is isolation from ground for the movable portion of the points. This is the weak spot on the front mount distributor. Another check you could do would be to hook up a 6 volt bulb to the top of the coil contact and turn the engine over the bulb should change from bright to dim when the points are working properly.
Happy Motoring
Claus
