Coil and Condenser checks
Jack R
10-14-2002 12:50:58
I have an 8N (Side distributor 6V) Can someone tell me how to check the Coil? I have a + and - terminal and the (Plug type) wire to the distributor. What should the voltage be and from where to where?
Also, is ther a way to verify the condenser?
Jack
Phil (NJ-AZ-SK)
10-14-2002 16:51:21
 Re: coil and Condenser checks in reply to Jack R, 10-14-2002 12:50:58
JackR, Connect your meter with One probe on the +ve term of the coil and the other probe on the -ve term of the coil (do NOT measure to ground)
Points open = 0.00 v (zero) this is very important because it tells you if you have a short, hi res or low res in the Dist Circuit causing current flow. When the points are open absolutly NO current should flow = 0.00 volts
Points Closed = ~6.0 v ~ Battey Voltage. If this voltage is lower it means Ignition switch or Points are resistive.
Hope This Helps,
Dell (WA)
10-14-2002 13:35:11
Jack..... .....a condenser/capacitor is 2 metal conductors separated by an insulator. It is generally 2 tinfoil sheets separated by plastic or wax sheet insulator and rolled up so it fits.
It is measured in Farids (named after some old dead dude that discovered it) But a Farid is really very very very large (about the size of a room). So most capacitors are measured in microfarids or micromicrofarids or picofarids.
While this may or maynot be of interest, you need to understand so you can visualize the 2 types of eazy checks for capacitor faults. MOST COMMON FAULT, is the insulator shorts/burns thru and nolonger separate the metal conductors. Ohm meter will show continunity between the inner terminal and outer shell. BAD condensor.
2nd MOST COMMON FAULT, is the insulator developes a high resistance leak, not quite a short. It will also measure on an Ohm meter as a resistance as opposed to a short (zero resistance). BAD condensor.
CAUTION: don't be fooled by the charge effect of the ohmmeters internal battery causing a momentary surge of electrons flowing into the 2 metal conductors of the capacitor.
The OTHER CAPACITOR FAILURE is OPEN circuit. It is most eazily diagnosted by burned points. You ignition will still make sparkies while a shorted or leaky condensor won't make sparkies.
To check a coil, again, use an ohmmeter to check a coil for continutity. Primary winding (+ to -) about 3 ohms and the secondary (sparkie hole) to eather + or - about 7000 ohms. Exact value not critical.
Voltage checks on a positive ground sidemount 6 volt coil, -6 volts on the coil (-) at all times. On the coil (+) you should read -6 when the points are open and ZERO volts when the points are closed. Coil + goes to battery + (ground) thru the points. Understand?
Don't try measuring voltage out your coil sparkie hole unless you wanna gett knocked on yer butt..... ....respectfully, Dell
Jack R
10-14-2002 13:47:10
 Re: Re: coil and Condenser checks in reply to Dell (WA), 10-14-2002 13:35:11
Thanks Dell,
A little backgound, I was Bushhoging last weekend and the tractor died. It was like someone hit the key. I haven't been able to get it going yet. I've checked the coil to dist. wire, I've visually checked everything, I've changed out the coil (as that is what it was last time) I'm at a loss, I'm not one to just put a bunch of parts in it, would like to test out first and be sure.
With the distributer cap off, I don't get any spark to the points that I can see,
Last time I messed with the points, I got things out of kilter and had to take it to a shop.
The tractor has run like a top for two years, no problems at all, just died in the field.
Any other ideas/suggestions?
Dell (WA)
10-14-2002 13:59:03
 Re: Re: Re: coil and Condenser checks in reply to Jack R, 10-14-2002 13:47:10
Jack..... ...check where your coil (+) wire goes thru the side of the distributor. There's an insulative washer down there that shorts out and won't make sparkies thatta way..... ..Dell
Jack R
10-14-2002 14:06:34
 Re: Re: Re: Re: coil and Condenser checks in reply to Dell (WA), 10-14-2002 13:59:03
Thanks, I noticed, mine doesn't have any gromet or insolator between that wire and the distributor, Could be a problem.
Also I thought that wire, (Primary coil wire) went to the Negative side of the coil. That's where mine is.. I'm sure the old one was on that side.
I'm all stock 6V, no conversion
Jack
Dell (WA)
10-14-2002 14:24:36
 Re: Re: Re: Re: Re: coil and Condenser checks in reply to Jack R, 10-14-2002 14:06:34
Jack..... ...The rule is: coil (+) to battery (+) wheather it is positive or negative ground system. If coil is miss-polarized, you'll lose about 25% to 40% of your sparkies.
You do know that the OEM 6 volt system, all N's are "positive" ground, don't you?
That means that the battery positive terminal is connected by heavy webbed conductor to tranny/engine/chassis ground bolt somewhere. And the battery negative (-) post is connected to the BIG starter solenoid terminal.
If it is miss-grounded (and it happens), that means the generator/voltage regulator must be re-polarized, if you decide to makeitt like the OEM factory positive ground..... ...respectfully, Dell
Jack R
10-14-2002 14:29:49
 Re: Re: Re: Re: Re: Re: coil and Condenser checks in reply to Dell (WA), 10-14-2002 14:24:36
Maybe that's the problem.
I'm heading home now and will check.
I'm positive ground. The positive side of the coil goes into a wire harness to never never land.
The negitive side of my coil goes into the distributer and connects to the points and the lead of fthe condensor.
Is that not wired up right?
Jack
DavidO
10-15-2002 05:24:01
 Re: Re: Re: Re: Re: Re: Re: coil and Condenser checks in reply to Jack R, 10-14-2002 14:29:49
If your postive terminal from the battery is connected to ground, the + terminal on the coil should go to the points and the - terminal from the coil should go into the wiring harness back towards the ignition switch. Having that backwards is a problem, but should not cause an otherwise good system to not crank, it just will not run as well as it should. Based on what you posted, I suspect that your points may have stopped working. Also check to be sure that you have voltage at the coil. Your ignition switch could also be the problem. Try puttin a jumper across it.
Jack R
10-15-2002 06:32:34
 Re: Re: Re: Re: Re: Re: Re: Re: coil and Condenser checks in reply to DavidO, 10-15-2002 05:24:01
Thanks David, I'm thinking points or condenser. Last time I changed the points, I got them messed up. Ended up taking it to the shop.
It was so weird though, just mowing along and it died. Started up a steep hill, so it put a load on the tractor, but have been mowing the same hill all day.
Jack
DavidO
10-15-2002 07:57:46
 Re: Re: Re: Re: Re: Re: Re: Re: Re: coil and Condenser checks in reply to Jack R, 10-15-2002 06:32:34
Well, I guess I have seen (at least) dozens of sets of points go out like a light bulb. Working fine, then nothing. Sometimes you get poor running first, but not always. Also, condensors usually last longer than points, but I have always considered them as a set. I NEVER replace points without replacing the condensor as well. Mainly because, if the condensor fails, the points will not last very long, and really, how much does a condensor cost? Points and condensor are relatively easy to replace, but if you are not comfortable doing it, get some help. Good luck with it. Let us know how it works out.
