Order Ford 8N Parts Online
8N won't start for rookie
mike
10-13-2002 15:40:35
The 8N I've had for a few weeks started missing, then stalling after backfiring, then wouldn't start at all. I thought it might be related to being overzealous with trying to clean her up, maybe getting water where it didn't belong. I pulled the hood and radiator ( '48 engine ) and replaced the distributor cap, points, rotor, and sparkplugs. All went well I thought, but she still won't start, turning over but not firing. She seems to be getting gas from the temporary tank I set up ( didn't want to replace the hood until I was sure she would start ) but I don't see spark on the plug I pulled. Do I need a new coil? Any suggestions?
I really enjoy reading the forum and hopefully will learn from all of you. Thanks.
scalawag
10-14-2002 06:59:14
 Re: 8N won't start for rookie in reply to mike, 10-13-2002 15:40:35
If you put new Champion spark plugs in it try taking them out and putting the old ones back in. My n wouldn't even fire with new Champion plugs. The Harley eat them up and the 55 Vette won't run on them either.
voltage at top of coil?==bj/8n/mt
10-14-2002 04:02:40
What voltage do you read at the coil top post? You don't say six or twelve volt system so all I can give you is it should read something and it should vary with cranking.
Post those results and somebody here can give you a lot better diagnosis.
Your mileage may vary
Dave OH
10-13-2002 22:58:02
I beleive the front mount distributor has the Ballist resistor in the circuit, if I am wrong I will be corrected. Check it for continuity. As said jump the ignition switch. Also make sure you streched the spring between the distributor cap and rotor to make good contact. I am sure you grounded the plug to the tractor when checking for spark. Dave OH
mike
10-14-2002 17:23:41
 Re: Re: 8N won't start for rookie in reply to Dave OH, 10-13-2002 22:58:02
Thanks Dave. It appears that the spring between the distributor cap and the rotor was the offender. All is well, I appreciate the suggestion, especially when its such a simple cure.
OH Boy
10-13-2002 19:50:05
Check your ignition switch.
OH Boy
10-13-2002 19:50:01
OH Boy
10-13-2002 19:49:52
Durk (OH)
10-13-2002 17:23:27
Did you change the condender when you changed your points and rotor and such? I would change it first then go from there. Point gap is .015 for front mount distributor but even with a wider gap it should start. Second guess would be a new coil.
mike
10-13-2002 18:04:25
 Re: Re: 8N won't start for rookie in reply to Durk (OH), 10-13-2002 17:23:27
I forgot to mention that the condenser was also changed. Thanks.
MikeC
10-13-2002 15:57:39
I have a question-did you pull the hood and radiator off because you needed to change the cap/rotor etc on the front mounted distributor? If so, did you realize that the front mounted distributor is made to be removed and placed on your workbench for repairs without the need to remove any sheet metal? And when you replace it it is made to be reinstalled only 1 direction so you can't get it backwards?
I would pull the distributor off and double check your points, etc. Also make sure that the small spring on the bottom of the coil is making good contact with the distributor.
mike
10-13-2002 18:09:02
 Re: Re: 8N won't start for rookie in reply to MikeC, 10-13-2002 15:57:39
It looked difficult to get to, so I assumed that the hood had to be lifted. Regardless, it was good practice for doing some sheet metal work this winter.
I'll look again at the distributor and coil.
Thanks
