?'n on 6-12 convert
gwhunter68
10-12-2002 19:58:20
Ok here goes, finally converted 2n to 12v. Kit from supplier included the single post alt. Diagram drawn for me showed not using the infamous ballast resistor, or the regulator. I liked Dell's remarks about adding inline the ballast with the voltage dropping resistor, like flashlight batteries I found in the arcives. ?'n is too which goes inline first, ballast or voltage. The one that came with the kit is after-mark 8NE10306. Next ?'n does anyone have a wiring diagram on a one wire alt. with using the 6-v coil
Dell (WA)
10-12-2002 20:19:24
 Re: ?'n on 6-12 convert in reply to gwhunter68, 10-12-2002 19:58:20
Hunter..... ..Why do you find it impossable to follow your 12 volt kit conversion instructions? I'm flattered that you think I know better than the kit maker, but I don't.
Are you still using your OEM 6 volt frontmount ignition coil? Or did the kit maker supply you with a new coil? You don't say and it makes a BIG difference.
As BJ/8n/mt sez: there many ways to convert to 12 volts and some of'em even work..... ....Dell
er...uh...
10-13-2002 11:47:14
 Re: Re: ?'n on 6-12 convert in reply to Dell (WA), 10-12-2002 20:19:24
Dell,
Why did you wife find you impossable to live with???...Hummm, did you treat her with the same respect as you do with fellers like "gwhunter68"? Why do you find it impossable to be on the same level as others here on the board instead of ya thinking you're above the rest? Why do you find it impossable to just answer peoples questions with repect and not belittle people?
Guess I never know....Why do you ask?.....cause I flunked mindreading and that makes it impossable to figure you out sometimes?
One bourbon, one shot, and one beer.
Cheers,
Belch,
Your buddy
