Order Ford 8N Parts Online
1951 8N hydraulic lift
David Coshman
10-11-2002 12:01:17
Do any of you guys out there think that removing the top and replacing the hydraulic piston and honing the cylinder would clear up my weak 8N lift????? ?????
Al
10-11-2002 16:41:47
 Re: 1951 8N hydraulic lift in reply to David Coshman, 10-11-2002 12:01:17
You can take the round plate off the side and look inside while the tractor is running and looking at the cylinder to see if oil is leaking out. If it is the cylinder ring is worn if not look somewhere else. This will save you from pulling off the top. Be careful do not stick anything in the hole especially your fingers and make sure the tractor can't move to run over top of you.
JimNC
10-11-2002 14:18:17
David, Could be the seals on the piston or possibly the relief valve.
