Need length of 3-point lift rod.
Jim Spencer
10-11-2002 07:00:44
I need to know the length of the left hand lift rod.
My Jubilee was restored by someone else and I think the lift rod is about 3/4" short.
I would like to know the distance from the centerline of the lower hole to the centerline of the upper pin \(upper hole). On my 8N it is 20".
On my Jubilee it is about 19-1/4".
My carryall does not sit all the way down on the ground when mounted on my Jubilee.
This 3/4" discrepency in the lift rod length equates to 3" in height at the drawbar.
TIA
Jim
EDDIE8N
10-11-2002 19:54:30
 Re: Need length of 3-point lift rod. in reply to Jim Spencer, 10-11-2002 07:00:44
Jim,
Master parts book shows left hand rod is same for 39 to 53; 9N,2N,8N,NAA,NAB. So your rod length should match jerry.in.ga.
My '48 is outside under tarp, in a rainstorm right now, or I would go measure it .
HTH,
EDDIE8N
jerry.in.ga
10-11-2002 13:25:35
I have a '50 8N and a '52 8N. Each left lift arm measures 20 1/4", center hole to center hole.
Jim Spencer
10-11-2002 13:40:16
 Re: Re: Need length of 3-point lift rod. in reply to jerry.in.ga, 10-11-2002 13:25:35
Thanks Jerry.
Sounds about right.
Jim
David Coe in MD
10-11-2002 12:07:33
I just measured mine and it's 23" from hole/pin to hole/pin (a Jubilee, but not with original parts) -- which explains why my lift can almost drag on the ground when lowered all the way. So I, too, wonder how long it's supposed to be.
David Coe in MD
10-11-2002 13:12:49
 Re: Re: Need length of 3-point lift rod. in reply to David Coe in MD, 10-11-2002 12:07:33
One of the tractor parts sites (samstractors) lists the length of the 9N,2N,8N,NAA left vertical link as 20 3/4". Doesn't say exactly where that's measured.
Further evidence that Jim's may be too short, and mine's definitely too long ;)
Dell (WA)
10-11-2002 07:49:41
Jim..... ....If I understand your description, thats why the r/h lift arm has a adjustable gearbox to level out side-to-side. And thats why the 3-point top link is adjustable, to level fore/aft..... ...Dell
Jim Spencer
10-11-2002 13:38:27
 Re: Re: Need length of 3-point lift rod. in reply to Dell (WA), 10-11-2002 07:49:41
Dell,
I understand I can level it out but the length makes quite a difference when using a scoop on the back.
Also when I use my carryall with my 9N I can set it all the way onto the ground. By using the leveling link on my Jubilee I could probably set the right rear corner on the ground but it would be tilted.
With my Jubilee it will not go down to the ground. It is about 2" off the ground.
I would like to know the proper dimensions between centerline of the pin holes. The overall length will not be as accurate as the distance between the centerline of the pin holes. If I cannot find out what the specified length is I will just assume it is 20" and add 3/4" to my Jubilee lift rod.
Jim
