Another first try at photos
tom brown IL
10-07-2002 19:45:49
to follow if pictures come up.
tom brown IL
10-07-2002 20:10:51
 Re: another first try at photos in reply to tom brown IL, 10-07-2002 19:45:49
I have some pictures of where to drill a inspection hole in the side of the tractor to check the condition of the clutch and also gently pry the clutch away from the flywheel.You drill a 1 1/8 hole with a hole saw. This gives you enough room to look in and also free up the clutch a little at a time. It doesn't take much.You can close up the hole with a 2 inch washer and a toggle bolt. The idea is to not split the tractor if the clutch is just stuck.I am goin back to the arcives to find more info on photos. Tom
MikeC
10-08-2002 03:34:51
 Re: Re: another first try at photos in reply to tom brown IL, 10-07-2002 20:10:51
Why would you put a hole through the casting when splitting the tractor is so simple? I put a new input shaft seal in mine last week and had it split in less than an hour taking my time. 2 jacks, some home made cribbing for safety and an 11/16 wrench is about all you need.
