Jubilee Taillight Repair
David Coe in MD
10-05-2002 19:59:45
Dear Frie-N-ds:
This is the tail light from my NAA Jubilee; I don't know if it's original equipment but it may well be; the plastic lens is labeled "DUOLAMP C1" at the top, with a "FoMoCo" script logo underneath, and says "A'S'A" and "STIMSONITE NO. 37A" at the bottom:
third party image
The lamp works intermittently, and I've found the problem; the wire is not well-connected to the bulb socket somewhere inside the rubber boot on the back of the shell and bracket (the bracket is spot-welded to the shell):
third party image
Do you have any suggestions on how to remove the rubber boot so I can repair the electrical connection? The rubber has become very brittle (and was also painted by someone, which may be why). Is there something I can use to soften it up, or can I just cut it away and replace it with something similar? Also, do you have any suggestions about repairing the cracks in the plastic?
Thanks.
Tyler (MD)
10-06-2002 16:23:11
 Re: Jubilee Taillight Repair in reply to David Coe in MD, 10-05-2002 19:59:45
third party image
We have one of those rear lights on our 640.
FWIW,
Tyman
Scott
10-06-2002 10:33:13
This is a NCA part# (1955-1957) tail lamp, since lights were dealer installed the farmer may have had the lights put on a few years after the tractor was bought, did you try cleaning or brushing the socket for a better connection?
David Coe in MD
10-06-2002 13:25:07
 Re: Re: Jubilee Taillight Repair in reply to Scott, 10-06-2002 10:33:13
oops, my reply to forworkma in this thread was really intended for you;
I hit the wrong 'reply' link.
forworkma
10-06-2002 06:24:42
This looks to me to be a tail light from an X01 series tractor. The NAA used the same light bracket as the 8N. I think all these X01 lights were attached to the bracket so you had to replace the entire unit- light and bracket.
forworkma
10-06-2002 18:43:06
 Re: Re: Jubilee Taillight Repair in reply to forworkma, 10-06-2002 06:24:42
Looking at the picture closer, I think this is actually an earlier tail light- not for the X01 series, but more for the X00 series. I beleive this is the first tail light to use a plastic lens (rather than glass) that fits over the housing, not held in place with a rim.
David Coe in MD
10-06-2002 13:21:23
Yes, I did clean the socket; the problem is definitely in
the connection between the wire and the socket base; by
moving the wire appropriately I can make it connect and disconnect predictably.
Thanks for the suggestions. Now I have to decide whether
to fix this non-NAA light or find one that's a better match.
David Coe in MD
10-06-2002 13:19:10
"NAA used the same bracket as the 8n"
Does that mean it also used the same light? I hope so,
'cause the one from the 8n looks a lot more stylish in
my opinion. If it wasn't the same light, can you describe
or show it to me? Thanks.
Levi (WA)
10-05-2002 22:05:34
If your not in any hurry to fix it you can cover it with silicone grease and it will soften it up but it will take some time.
